In input side I have 9 items, after removing duplicates, I see 3 items displays fine on output JSON,
When I click output side Binary, it just shows only one File, but it should display all 3 different files.
Attaching my image and providing workflow, kindly help.
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
- **n8n version:**
- **Database (default: SQLite):**
- **n8n EXECUTIONS_PROCESS setting (default: own, main):**
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**
- **Operating system:**
