Strange behaviour with if node and a boolean value
I have a Notion Node where I load a database page. Then I want to make specific changes based on the given attributes. I have a attribute which is a checkbox and which I parse to a boolean value inside of n8n. I then have a if-node to go one path if true and another if false - but the if-node seems not operate correctly - what am I missing?
  • n8n version: 1.106.3
Hello, @andrew.t9 hope all is good. Welcome to the community.
in your is_public, remove extra leading spaces:
then you also won’t need to type convert to Boolean in the previous node or use Convert types where required in the IF node.
I can run this workflow execute successfully.
@jabbson space is not actual issue.
Of course it is
But i can run without remove space!
The problem was not that the author couldn’t run the workflow. Read their post again, please.
Lol I don’t know where the blanks are coming from… but it makes totally sense that it then behaves this way…
Thank you!
You are welcome
I know but see my above execution work properly.
“public”: false. excute this “node notPublic_and_task_Id_exists”
@Dhruv29
Once again, bud, the problem was not with the execution and this is solved now.
Have a good day :call_me_hand:
