Struggling to Embed n8n Chatbot in Shopify – Proxy Setup Failing with 500 Errors (Not Very Technical)
Hi, I’m not very technical but I’m trying to embed an n8n chatbot into my Shopify store. I’ve tried several proxy setups to securely send messages to my n8n workflow, but I keep running into errors and can’t get the integration to work. Here’s what I’ve tried so far:
Summary of Solutions Attempted (Embed/Proxy Issue)
Goal:
Embed an n8n-powered chatbot into my Shopify store using a secure proxy that injects an Authorization header, so my API key isn’t exposed client-side. I need to make POST requests from the Shopify frontend (iframe or AJAX) to n8n’s /chat endpoint.
Solutions Tried and Outcomes:
  1. Direct n8n API call from Shopify frontend
  • Result: Not possible, as exposing the API key to the browser is insecure and leads to CORS/auth problems.
  1. Supabase Edge Function as Proxy
  • Set up an Edge Function to forward requests and add the Authorization header using an env variable.
  • Tried both CLI and Web UI deployments.
  • Result: All deployments returned a static {"code":401,"message":"Missing authorization header"} error, no matter what code was deployed. Function code was not being updated or executed. (Suspected platform bug or cache issue, already escalated to Supabase support.)
  1. Cloudflare Pages as Proxy
  • Attempted to use Cloudflare Pages to proxy requests and inject headers.
  • Result: Not viable, since Pages only supports static sites (no serverless code execution).
  1. Cloudflare Workers as Proxy (RECOMMENDED SETUP)
  • Created a Worker to accept POST requests, add the Authorization header from a secret, and forward to n8n /chat.
  • Worker GET test worked fine (“Cloudflare Worker is running!”).
  • POST requests from curl to the Worker resulted in a 500 Internal Server Error from n8n.
  • Debugging revealed: The error is NOT from the Worker (proxy), but from n8n itself—direct POST to the n8n /chat endpoint also returns 500 Internal Server Error.
  • Conclusion: The Worker is correctly proxying requests, but n8n returns 500s for all POSTs (even with correct Authorization).
  1. Checked n8n Execution History
  • Found that some executions were successful, but current POST attempts still result in 500 errors.
  • Not sure if the issue is with request format, webhook node settings, or internal n8n logic.
Current State:
  • Proxying through Cloudflare Worker is working as intended (GET works, POST is forwarded).
  • All POST requests to n8n /chat return 500 Internal Server Error, even when called directly via curl with the correct API key and JSON.
  • Suspect the issue is either with:
    • n8n webhook node configuration (method, payload shape),
    • workflow logic error,
    • or something environmental in n8n.
What I’m Asking:
  • Has anyone successfully embedded an n8n chatbot in Shopify (or any frontend) using a secure proxy for header injection?
  • What is the best way to configure the webhook node and workflow to avoid 500 errors on POST?
  • Any known pitfalls with n8n’s handling of webhook payloads, headers, or authentication that might cause this?
Happy to provide code snippets, workflow exports, or logs if helpful!
