This is the workflow I made, but the problem is on lovable i built a website for it. So the the user before posting review and edit it. Bt unable to get the generated image from n8n to lovable. If I am choosing only for text generation then successfully getting outputs on the lovable website. In case of both image nd text then my website showing generation failed.
I tried telling it that i am getting output image as binary file. use convert to file in n8n workflow bt then also failed to render image and text both on my lovable website.
I am getting both image and text output from my last endpoint webhook on n8n but not on my website.
Please help me if i make any error in this n8n workflow. So provide me a better solution.
