Stuck inserting into Qdrant
Hello everyone, :wave:
After seeing the video by @Anthony_Lee on building a vector store with Qdrant, I wanted to try myself with a custom list of terms (10k) I want to use to classify projects. So I copied how @jimleuk did in his templates.
Unfortunately, I cannot figure out how to insert into Qdrant.
Here is my workflow:
[EDIT] For some reason the pinned data does not seem to show:
"good_label":
"combusting preparations [chemical additives to motor fuel]",
"class_id_int":
"1",
"good_id":
"U100040",
"class_id":
"U241824",
"good_id_int":
"0001"
"good_label":
"adhesives for industrial purposes",
"class_id_int":
"1",
"good_id":
"U100042",
"class_id":
"U241824",
"good_id_int":
"0002"
"good_label":
"salt for preserving, other than for foodstuffs",
"class_id_int":
"1",
"good_id":
"U100044",
"class_id":
"U241824",
"good_id_int":
"0003"
"good_label":
"auxiliary fluids for use with abrasives",
"class_id_int":
"1",
"good_id":
"U100046",
"class_id":
"U241824",
"good_id_int":
"0004"
"good_label":
"vulcanization accelerators",
"class_id_int":
"1",
"good_id":
"U100048",
"class_id":
"U241824",
"good_id_int":
"0005"
"good_label":
"anti-frothing solutions for batteries",
"class_id_int":
"1",
"good_id":
"U100050",
"class_id":
"U241824",
"good_id_int":
"0006"
"good_label":
"acetates [chemicals]",
"class_id_int":
"1",
"good_id":
"U100052",
"class_id":
"U241824",
"good_id_int":
"0007"
"good_label":
"acetate of cellulose, unprocessed",
"class_id_int":
"1",
"good_id":
"U100054",
"class_id":
"U241824",
"good_id_int":
"0008"
"good_label":
"bacteriological preparations for acetification",
"class_id_int":
"1",
"good_id":
"U100056",
"class_id":
"U241824",
"good_id_int":
"0009"
"good_label":
"acetic anhydride",
"class_id_int":
"1",
"good_id":
"U100058",
"class_id":
"U241824",
"good_id_int":
"0010"
The vector database has this config:
  "params": {
    "vectors": {
      "term_vector": {
        "size": 300,
        "distance": "Cosine"
    "shard_number": 1,
    "replication_factor": 1,
    "write_consistency_factor": 1,
    "on_disk_payload": true
  "hnsw_config": {
    "m": 16,
    "ef_construct": 100,
    "full_scan_threshold": 10000,
    "max_indexing_threads": 0,
    "on_disk": false
  "optimizer_config": {
    "deleted_threshold": 0.2,
    "vacuum_min_vector_number": 1000,
    "default_segment_number": 2,
    "max_segment_size": null,
    "memmap_threshold": null,
    "indexing_threshold": 20000,
    "flush_interval_sec": 5,
    "max_optimization_threads": null
  "wal_config": {
    "wal_capacity_mb": 32,
    "wal_segments_ahead": 0
  "quantization_config": null
And finally here is the error I get:
Fyi:
  • If I run the CURL /collections/goods-services, I get no error so the collection does exist.
  • I tried inserting with no metadata but I get the same error.
Thank you very much for your help! :pray:
Joachim
  • n8n version: 1.54.1
  • Database (default: SQLite): Default
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Default
  • Operating system: Ubuntu Server
I only posted that video - it was @Anthony_Lee who created it :slight_smile:
I found the solution, apparently I did not search enough!
Fixing that :slight_smile:
