I think I’ve correctly configured the Notion node, with an API that seems to work, but when I try to get a list of all databases I have, I don’t get any records as a result (empty json). Don’t found any place to configure specific access to a specific database so I’ve assumed that all my DBs are shared through tha API, but still I don’t understand why it doesn’t work.
Can you help me on this one please ?
Best,
Sylvain
Please share the workflow
- n8n version: latest
- Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]:
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:docker install to heroku
