I see people using SQL Agent but when i do the exact same thing, it’s not working ! I’m pretty mad after 2 days on basic topic, thus i’m looking for help. I have an idea of the problem but don’t know ho to solve it.
I can’t make a standard SQL Agent work. I get the error :
Could not parse LLM output: I don’t know. Troubleshooting URL: OUTPUT_PARSING_FAILURE | 🦜️🔗 Langchain
The execution is of the node gets this result:
Question: Give me the name of product 103
Thought: I should look at the tables in the database to see what I can query.
Action: [[“list-tables-sql”]]
Action Input: “”
Observation: [[“list-tables-sql”]] is not a valid tool, try another one.
I think the problem is in the prompt
- The suspected line in my prompt: Action: the action to take, should be one of [[“query-sql”,“info-sql”,“list-tables-sql”,“query-checker”]]
- The same line in printscreen from other people: Action: the action to take, should be one of [query-sql,info-sql,list-tables-sql,query-checker]
Do you know how to change it ?
I tried MySql and PostgreSQL databases and same results. Both databases are accessible correctly using a node.
I tried to modify the prompt in many ways, including giving the database schema but i failed to solve the problem.
- **n8n version: 1.69
- **Database (default: SQLite): Postgre or Mysql
- **n8n EXECUTIONS_PROCESS setting (default: own, main): own
- **Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
- **Operating system: Windows10
