Sub workflow with Human in the Loop does not return an output
I have a main workflow and a sub workflow.
I have a “Human in the loop” node in a sub-workflow.
The issue is that I can’t get an output value from the sub-workflow in the main workflow. I always get a value of the previous node (just before the sub-workflow execution).
If I remve “Human in the loop” - everything works fine.
No errors, just no output.
Main workflow
Sub workflow
“output”: “main_flow”
Expected output
“output”: “subprocess”
  • n8n version: 1.107.3
  • n8n EXECUTIONS_PROCESS setting (default: own, main): sorry have no idea
Unfortunately this is a limitation of n8n that will not be fixed until a major update (like n8n 2.0). Anytime you use a wait node in a sub-workflow it will not output data back to the main one.
You will either need to do that in the main one, or if you can’t, feel free to open a new thread and post your workflow there, so we can brainstorm on workarounds. I did one just today.
Feel free to mark as solution if this helped :slight_smile:
Thank you for pointing this out! Hope there will be a major release this year.
There was, and this is now possible: n8n v2.0 breaking changes | n8n Docs :slight_smile:
