Summarization Chain -> Final Prompt and Individual Summary descriptions are inverted
In the Summarization Chain node, if you add the Summarization Method and Prompts option, when the Map Reduce Summarization Method is selected, the display names for Final Prompt to Combine and Individual Summary Prompt parameters are inverted, as well as its hints.
  • n8n version: 1.24.0
Created a PR that targets this issue: Switched 'Final Prompt to Combine' and 'Individual Summary Prompt' op… by mprytoluk · Pull Request #8391 · n8n-io/n8n · GitHub
I’ve added a picture that shows that the prompts names and types are indeed reversed:
Thanks so much for reporting and fixing this @miguel-mconf :bowing_man:
Our local AI specialist @oleg is out this week but I am sure he’ll take a look as soon as he can after his return.
I’m bumping this, since it is still incorrect in version 1.35.0.
Any thoughts on this?
New version [email protected] got released which includes the GitHub PR 8391.
