Supabase does not return records, while Postgres does
I’m evaluating Supabase (free account). I have inserted 28 records in a “contacts” table.
Supabase node (GetMany) does not return anything, while Posgres node (Select) returns the expected result.
No error, Supabase just returns nothing
  • n8n version: 1.56.2
Hi @hsteph,
Supabase returns an empty array when Row Level Security (RLS) is enabled on a table but no policies are set. Could that be the issue here?
See here: Row Level Security | Supabase Docs
thanks @aya ! I have executed the following alter table “contacts” disable row level security;
and I can access my supabase.
thank you !
