SurveyMonkey trigger issue
I am getting this error below after adding SurveyMonkey credentials.
SurveyMonkey error response [400]: Invalid schema in the body provided.
Any help please.
Thanks
Welcome to the community.
Can you please share how you setup the node? So that I can test it with the same parameters.
Thanks Ricardo
I followed this tutorial
I used the access token
Below is my workflow
Thanks
I restarted my docker container and its running well now.
Thanks for the help.
