Switch and If node seem not properly working
I am using the Switch node (before I’ve also used the If node, and same problem), basically I have made a function inside the Value1 as expression, following this post I made some month ago (Using Expression route in Switch node - #2 by Gabriele_Bracciali)
I am checking 2 number, x < y ? continue : exit
when the condition needs to exit it basically doesn t return any output and the workflow stop it
  • n8n version: 0.231.3
  • Running n8n via self-hosted:
Hey @Gabriele_Bracciali,
Can you share the JSON output of Set offset and get list2 so we can do some testing?
Hi @Jon , thank you for replying me.
So the first run the output of the nodes wil be:
Set offset: empty item
get list2:
“count”: 235
This workflow work like:
Obtain a list from A, obtain a FULL list from B, need to match list A with FULL list in B
But maybe I’ve found a solution doing like this:
{{ $(‘Set offset’).first().json[“offset”] || 0 < $(‘get list2’).first().json[“count”] ? “continue”: “exit” }}
Cause the problem was the first run, when the “Set offset” output was undefined
