Switch and merge node
I know that the merge node needs to receive data on the 2 inputs, and when it doesn’t have it, it requests data from the previous node.
But I’m having a problem, even one of the previous node having data it requests another node which returns 2 items.
did I make a mistake in the way I set up the flow?
Can you please share screenshot including the trigger node. Thanks!
yes i can, no problem
