Switch Node not Outputting
I’m not getting anything to output from the switch for fallback. I create Output 1 and set it to match on if exists and can’t get an output from that either even though it’s saying it matched.
No error message
“headers”: {
“host”: “xxxxxx”,
“x-forwarded-scheme”: “https”,
“x-forwarded-proto”: “https”,
“x-forwarded-for”: “172.69.xx.xx”,
“x-real-ip”: “172.69.xx.xx”,
“content-length”: “317”,
“cdn-loop”: “cloudflare”,
“cf-ipcountry”: “US”,
“accept-encoding”: “gzip, br”,
“cf-ray”: “8903dba33976109c-ORD”,
“cf-visitor”: “{“scheme”:“https”}”,
“content-type”: “application/json”,
“via”: “Proxyscotch/1.1”,
“user-agent”: “Proxyscotch/1.1”,
“cf-connecting-ip”: “2600:1900:2000:a3::1:1b01”
“params”: {
“query”: {
“body”: {
“customer”: {
“firstName”: “John”,
“lastName”: “Doe”,
“address”: {
“street”: “123 Maple Street”,
“city”: “Springfield”,
“state”: “IL”,
“zipCode”: “62701”
“servicesRequested”: [
“Plumbing”,
“Electrical”,
“Trees”
“date”: “2024-06-07”
“webhookUrl”: “xxxxxxx”,
“executionMode”: “test”
  • n8n version: 1.42.1
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Not sure what this is
  • Operating system: Ubuntu 24
Update on this… for some reason that workflow was just buggy, not sure why. I create a new workflow and copied the webhook trigger as well as most of my other nodes into the new workflow, then created a new switch node, and that workflow ran just fine! It’s almost like the old workflow got corrupted somehow, no idea.
Hi @Crypto_T3CH
I could not recreate the issue you had, but glad that you were able to resolve it! :slight_smile:
