Switch node routing, same value multiple output
Hello everyone, I am using the Switch node for route contact from A to multiple B.
The input items has a field with the name of the accounts, this field can have multiple name, Account1 Account2 etc…
That’s why I am using the switch node, checking this field, and using the Routing rules “Contain”.
The problem is when a contact has 2 account, this contact needs to be save in 2 account, but the switch node route it to the first account and skip the other one.
Is there a way to route the input in all the output with that rule?
  • n8n version: 0.231.3
Hi @Gabriele_Bracciali, perhaps you want to try using multiple Filter nodes for such cases rather than one Switch node? An item can be picked up by multiple filters, so I think this would achieve what you have in mind.
Hi @MutedJam thank you for replying me.
Actually yes, that’s a great solution, I’ve added 4 filter with 4 different routing condition 1 for each account.
It’s working properly, thank you like always!
