Syntax error when inserting multiple rows using Microsoft SQL node with Azure Dedicated SQL pool
When inserting multiple rows (items) into an Azure Dedicated SQL pool (on a regular Azure SQL Server), we receive a syntax error from the DB (“Parse error at line: 1, column: 73: Incorrect syntax near ‘,’“). Using the exact same node but with Credentials pointing to a different DB (a regular SQL database) on the same server works without issue. Inserting a single row also works on the Dedicated SQL pool. But when we try to insert more than on row, the syntax error occurs.
Parse error at line: 1, column: 79: Incorrect syntax near ‘,’.
  • n8n version: 1.108.2
  • Operating system: Debian 5.10.237-1 (2025-05-19) x86_64
Hey @Cathryn17 welcome to the community.
Regarding your questions The problem is that Dedicated SQL Pools don’t support the same multi-row INSERT syntax that regular SQL Server does.
Thanks for your input, @Zelite! I wasn’t aware of the different syntax in Dedicated SQL Pools für multi-row inserts. That’s unfortunate. Do you think a feature request for this makes sense and has a realistic chance of being accepted?
Yes @Cathryn17 submit a feature request, I feel this is exactly the kind of improvement the n8n team would welcome.
And if you found the answers above helpful kindly mark as the solution.
Thanks, @Zelite , I created a new feature request here: Add support for inserting multiple rows in Azure Dedicated SQL Pool and marked your reply as the solution.
Good good mate thanks
