I encountered a problem that the chain does not always start starting with the Telegram trigger that listens to updates in the bot. At the same time, the script is enabled, and if I turn it off and on again, the chain starts working, what could this be connected with? If I run a chain inside a script and test the flow, everything always works.
- n8n version:
- Database (default: SQLite):
- Operating system:
n8n version: 1.68.0
Database (default: SQLite): PostgreSQL
n8n EXECUTIONS_PROCESS setting (default: own, main): default: own, main
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: Ubuntu 22.04.5 LTS (GNU/Linux 5.15.0-125-generic x86_64)
Hi @maksilo,
Welcome to the community ![]()
Could you share your workflow so we can try to reproduce it?
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
