Telegram node "send and wait response" should include thread_id and parse_mode
As you can see the operation to “send and wait response” is missing the following options
  • parse mode
  • thread_id
why those options are useful
send and wait response” is a great to keep the “human in the loop”. Since it make sense to use them in a collaborative environment, using thread_id a great way to isolate the bot actions inside a telegram private group thread (since you can silent thread notifications).
without thread_id the node send messages, but they are sent into the default thread.
parse mode is also useful, because you may want to send a markdown or html payload inside the message.
to be clear
most other telegram operations support the thread_id option.
To Reproduce
Try to send a message inside a thread using “send and wait for answer” operation.
Expected behavior
the message should be delivered inside the thread_id specified.
Debug Info
it’s a missing option therefore there is no debug, since in inside other telegram operations the option is available.
Operating System
Docker
n8n Version
1.103.2
Node.js Version
22.17.0
Database
SQLite (default)
Execution mode
main (default)
Hosting
self hosted
