Are you by any chance testing multiple different workflows or manually run this workflow in the meantime? Afaik, Telegram only supports a single active webhook at a time.
So adding a new Telegram trigger will break existing Telegram trigger nodes. The same would happen if you manually executing a workflow including a Telegram trigger while your workflow is active (as this will register a new webhook with Telegram using the test URL and thus disable the production one).
Hi @MutedJam
I only have one workflow. I’ve been trying to beat this error for 2 days now.
restarting n8n fixes the error for about 2 minutes, after which the trigger stops working on one’s own
trying to delete and re-add the workflow, re-create the bot, delete and re-add the token does not fix the error
my programming skill is low and i can’t set my own URL to avoid using tunnel URL
So this could suggest an unstable network connection breaking the tunnel after a bit.
If so, the tunnel URL might indeed be the culprit here. The desktop app doesn’t support your own URLs, but a self-hosted server deployment would (though this can be a lot of work, especially if you have not done this before).
To rule out network problems you could also consider signing up to n8n cloud temporarily (this is a paid service, but the first 30 days are free).
Your router might not handle SSL termination (you might need a reverse proxy for that or add existing SSL certificates to n8n using the N8N_SSL_CERT and N8N_SSL_KEYenvironment variables).
For an n8n set up that generates its own valid SSL certificate and is capable of listening on port 80 + 443 you might want to use the docker compose approach described here.
Error is hiding somewhere in my home router (MikroTik hap ac^2) or home server with Ubuntu Server 22.04.
Running n8n in docker didn’t solve the problem.
Migrating the server to the Oracle cloud server on Ubuntu Server 20.04 solved the problem.
