Telegram Webhook does not work
Telegram Webhook does not work. I have been scratching for past week to get this fixed but none of the answers here for similar issue worked for. me.
Below i have set with docker environment
- WEBHOOK_URL=https://n8n.xxxxxx.in/
- WEBHOOK_TUNNEL_URL=https://n8n.xxxxxx.in
- VUE_APP_URL_BASE_API=https://n8n.xxxxxx.in/
I am using nginx proxy and config has websockets enabled. I tried with SSE it does not work.
location / {
proxy_set_header Connection “upgrade”;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Frame-Options SAMEORIGIN;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
client_max_body_size 50m;
client_body_buffer_size 1m;
proxy_read_timeout 600s;
proxy_buffering off;
proxy_cache off;
proxy_pass http://host:port;
location ~ ^/(webhook|webhook-test) {
    proxy_set_header Connection '';
    chunked_transfer_encoding off;
    proxy_set_header Connection "upgrade";
    proxy_cache off;
It just waits “Listening for test event” no error what so ever
It pretty simple. I added telegram message trigger and w
  • **n8n version: 1.36.1
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker with Nginx reverse proxy
  • **Operating system: debian
I have tried this with cloud version and of course it works but it does not work with my selfhosted version.
Hey @isunny,
I suspect the issue will be with your nginx configuration, I would start by removing the location ~ ^/(webhook|webhook-test) { section as you don’t really need it.
From there I would update the / location to use the below which we know works then make changes from there.
location / {
    proxy_pass http://127.0.0.1:5678;
    proxy_set_header Connection 'Upgrade';
    proxy_http_version 1.1;
Thanks for the reply. I updated to this and still does not work. When i test the flow it just keeps waiting for trigger and nothing happens.
In my flow i just have a telegram trigger event.
Hey @isunny,
That is unusual, Do you already have a webhook registered for the telegram bot you are using?
Hi Yes i have registered using the production Webhook URL by calling the below URL and got the response it is registered.
Is there anything else to be done ?
https://api.telegram.org/bot{my_bot_token}/setWebhook?url=
OK after little digging i found that telegram shows this error after setting webhook
“SSL error {error:0A000086:SSL routines::certificate verify failed}”
Once i trigger the event, the webhook URL is removed.
I am using a letsencrypt SSL.
Ok I have managed to fix this by using different SSL and in Nginx it requires full chain to be set.
