The definitive guide to custom NPM modules for self-hosted instances
I just spent the last 3 hours trying to get custom npm modules working.
Literally 14 community.n8n.io tabs open but it still took so long.
I feel like I’ve been through a car wash in a mini cooper convertible with the roof down.
But fear not young lass, for in this post I’m going to show you how to get your shit running without going crazy.
And in case you’re wondering, I’m running the vanilla Docker container on a vanilla Digital Ocean droplet with the vanilla database and the most recent version of n8n.
Here’s the proof of work.
Now, let’s get into it.
First of all, to my understanding there are only 2 basic parts to this setup:
The first is your .env file which is needed for the configuration of your n8n instance.
Mine is almost 100% default:
# Replace <directory-path> with the path where you created folders earlier
# I haven't touched this
DATA_FOLDER=/home/adomakins/n8n-docker-caddy
# The top level domain to serve from, this should be the same as the subdomain you created above
# Of course I've touched this
DOMAIN_NAME=yourmom.com
NODE_FUNCTION_ALLOW_EXTERNAL=*
# For some reason I had export in front of this earlier, but now I don't. Must not be important.
# The subdomain to serve from
SUBDOMAIN=n8n
# DOMAIN_NAME and SUBDOMAIN combined decide where n8n will be reachable from
# above example would result in: <https://n8n.example.com>
# Optional timezone to set which gets used by Cron-Node by default
# If not set New York time will be used
# I changed this, I believe it should make everything UTC
GENERIC_TIMEZONE=Etc/UTC
# The email address to use for the SSL certificate creation
# Redacted (you should probably change this)
SSL_EMAIL=poop@butt.com
The next part is your docker-compose.yml file.
This can be a bit of a confusing bastard if you’re too stubborn like me to study Docker for 10 minutes.
But, it should be fine because you can just copy mine:
version: "3.7" # No idea what this means
services: # Same here, just left it alone
  caddy:
    image: caddy:latest
    restart: unless-stopped
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - caddy_data:/data
      - ${DATA_FOLDER}/caddy_config:/config
      - ${DATA_FOLDER}/caddy_config/Caddyfile:/etc/caddy/Caddyfile
  n8n:
    container_name: n8n # nice to give it a name... I'm not 100% sure if this does anything though
    image: n8nio/n8n:latest # pulling the newest version of n8n everytime I do a rebuild! (default)
    restart: always
    ports:
      - 5678:5678
    environment:
      - NODE_FUNCTION_ALLOW_EXTERNAL=${NODE_FUNCTION_ALLOW_EXTERNAL} # VERY FUCKING IMPORTANT!!!!!
      - N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
      - N8N_PORT=5678
      - N8N_PROTOCOL=https
      - NODE_ENV=production
      - WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
      - GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
    volumes:
      - n8n_data:/home/node/.n8n
      - ${DATA_FOLDER}/local_files:/files
volumes:
  caddy_data:
    external: true
  n8n_data:
    external: true
Hopefully you saw that note above about this line:
Not having this had me closer to suicide than I’m comfortable with admitting.
I think I was struggling for about 3 hours because I was missing this. The other stuff isn’t rocket science. But telling your docker container to bring in the right nodes is probably a little bit important. (To clarify: It’s very fucking important)
But now, it’s time for the real pièce de résistance.
Because up to this point we haven’t actually imported any modules.
So here we go.
In your project directory (for me it’s /home/[username]/n8n-docker-caddy (the same directory as .env and docker-compose.yml)) you want to create a new file called run.sh (actually, call it whatever you want but just something with a .sh at the end)
If you’re a real one then you’re going to be using vi run.sh at this point.
Then I want you to put this script in there:
#!/bin/bash
# Stop current containers
docker-compose down
# Start containers
docker-compose up -d
# Install custom modules
echo "Installing external modules"
docker-compose exec -u root n8n npm install -g ytdl-core
# Add any other modules you need
echo "Installation done"
echo "N8N ready for use"
In this example I’m installing ytdl-core, but just swap that out with whatever you’re installing.
Now again for you real ones, it’s time to hit ESC :wq (that means go back to the terminal for you soy devs).
So once you’re back in the terminal, just hit it with a chmod +x run.sh and you’re just about good to go.
Now, it’s important to make sure that you’re logged in as the root user. I think.
I’m actually not 100% sure, and I can’t be bothered to test it out as a normal user, so maybe give it a whirl if you can’t be bothered to switch to root, idk.
Anyways.
At this point all you should have to do is hit ./run.sh which will run your new executable, and Voilà.
Your old container will stop, your new container will start, and your package(s) will be installed.
Then just refresh your n8n page, take one last nasty breath of this no-packages-having air, and hit “Test step” to enter a world of bliss.
Just make sure you’re doing it like const ytdl = require('ytdl-core'); and not trying to use import. I don’t think that works. At least ChatGPT told me that shouldn’t work. But ChatGPT is also kind of a saboteur sometimes so maybe give it a whirl if you like.
And if you’re still here and it didn’t work, well that sucks. But a permissions error might be solved with a good ol’ sudo or by switching to the root user.
One more note:
Despite the jokes, I highly recommend using Zed or VS Code to SSH into your server so that you can see all of your files easily without typing cd or vi 1,000,000 times.
As a bonus, if you’re using an AI API with Zed.dev or Continue.dev, you can chat with Claude to fix your issues using context from the codebase.
Claude is the one that helped me fix my issue. Not ChatGPT. ChatGPT had me chasing my own tail for about 3 hours.
Also, @yousername has a thread on here that really helped, actually giving me the contents of run.sh in the first place.
Hey @adomakins,
I am a big fan of this but can you maybe clean it up a little bit to keep it friendly :slight_smile:
I would also like to add an other option is to use a Dockerfile with
FROM n8nio/n8n:latest
USER root
RUN npm install -g ytdl-core
USER node
You can then update your Compose file replace image with build like below.
  n8n:
    container_name: n8n
    build: .
    restart: always
    ports:
      - 5678:5678
    environment:
      - N8N_PORT=5678
    volumes:
So now if you use the docker compose file commands it will automatically build your image with the latest version of n8n and your module.
Okay gotcha, yeah that looks a little bit more straight forward!
Can you suggest where to run
USER root
USER node
I installed using: Docker Compose | n8n Docs
THANK YOU! This post helped me so much when ChatGPT had me chasing my tail for hours, too. Thank you!
I wish topics were not automatically closed after some time of inactivity!
We find a lot of people sharing the same problems we face, but we never get to learn how they solved it because the topic was closed too early.
And we never know how outdated is the info we are checking in this forum because nobody can post a reply pointing to a newer/better solution.
Ty so much guys for sharing the solution! @Jon idea helped me to set up my container exactly the way I needed!
Hello,
Just wanted to share the alternative I am using, I don’t remember who sent me the snippet I use but this works really well.
Hope that helps!
This is the solution I went with. Better than rebuilding the base image after pnpm add in task-runner project because –
  • side steps long compilation + build dependencies
  • upstream changes to lockfile creates merge conflicts.
Installing to the global space is the chef’s kiss solution to both of the above problems IMO.
This requires a custom Dockerfile that the docker-compose file can build.
My example:
USER root
RUN npm install -g --unsafe-perm selenium-webdriver
USER node
ENV NODE_PATH /usr/local/lib/node_modules
services:
  n8n:
    build:
      context: .
      dockerfile: /path/to/Dockerfile
#    image: docker.n8n.io/n8nio/n8n
    env_file:
      - /etc/n8n/.env
    ports:
      - "5678:5678"
    volumes:
      - /home/n8n/.n8n:/home/node/.n8n # in production
      - /var/lib/n8n:/var/lib/n8n
    extra_hosts:
      - "host.docker.internal:host-gateway" # needed to connect to the host's postgres
    environment:
      - N8N_LOG_LEVEL=debug
#      - NODE_FUNCTION_ALLOW_EXTERNAL=selenium-webdriver
      - GENERIC_TIMEZONE=Europe/Berlin # Affects schedule triggers
      - TZ=Europe/Berlin # Affects utilities like `date`
      - N8N_RUNNERS_ENABLED=true # future proofing because running without task runners is going to be deprecated
      - N8N_SECURE_COOKIE=false # to allow running without TLS(HTTPS)
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_HOST=host.docker.internal
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_SCHEMA=public
      # DB_POSTGRESDB_USER and DB_POSTGRESDB_PASSWORD in .env files
Should this still work (n8n v2.3.2)?
None of the above proposed solutions works for me.
Whenever I try to use it to e.g. install xlsx-js-style and then use it in a code node like this:
const xlsx =require(‘xlsx-js-style’);
I get:
**Cannot find module 'xlsx-js-style' Require stack: - /usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+task-runner@file+packages+@n8n+task-runner_@opentelemetry+api@1.9.0_@opentelemetry_eb51b38615a039445701c88b088f88d0/node_modules/@n8n/task-runner/dist/js-task-runner/require-resolver.js - /usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+task-runner@file+packages+@n8n+task-runner_@opentelemetry+api@1.9.0_@opentelemetry_eb51b38615a039445701c88b088f88d0/node_modules/@n8n/task-runner/dist/js-task-runner/js-task-runner.js - /usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+task-runner@file+packages+@n8n+task-runner_@opentelemetry+api@1.9.0_@opentelemetry_eb51b38615a039445701c88b088f88d0/node_modules/@n8n/task-runner/dist/start.js
UPDATE: This works when running the execution in debug mode. But when its running scheudled I get the following error: Module '/home/node/.n8n/node_modules/web-push' is disallowed [line 2]
I got it to work on v2 today. Im not sure if that is an elegant solution and it took a lot of trial and error. But in my case this dockerfile (for the module web-push) works.
USER root
1. Install web-push AND all its dependencies in a clean temp folder
WORKDIR /tmp
RUN npm install web-push
2. “Smuggle” EVERYTHING into n8n’s internal node_modules
Use ‘*’ to copy web-push, http_ece, jws, and everything else npm installed.
The flag ‘-n’ prevents overwriting existing n8n modules (safety first).
RUN cp -rn /tmp/node_modules/* /usr/local/lib/node_modules/n8n/node_modules/ || true
3. Cleanup
RUN rm -rf /tmp/node_modules
4. Switch back to standard user
USER node
WORKDIR /home/node
this method simply works
After hours of trial and error this works. I don’t understand how the n8n team doesn’t have offical docs for installing npm modules. I mean you can install custom nodes now (which are npm packages) directly in the UI but not regular npm packages? (Package name must start with n8n-nodes-)
It does? For me it still only works in debug mode. In production it still shows the error from my updated comment. Im going crazy trying to fix it.
In n8n v1 I used this dockerfile to install papaparse for my code nodes:
USER root
RUN npm install -g papaparse
USER node
For n8n v2 this didn’t work so I tried this using your comment and it works:
USER root
WORKDIR /tmp
RUN npm install papaparse
USER node
My docker-compose:
version: “3.8”
services:
n8n:
image: my_custom_image
pull_policy: always
restart: always
environment:
  • N8N_HOST=${N8N_HOST}
  • N8N_PORT=${N8N_PORT}
  • N8N_PROTOCOL=http
  • NODE_ENV=production
  • WEBHOOK_URL=https://${N8N_HOST}/
  • GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
  • N8N_SECURE_COOKIE=false
  • NODE_FUNCTION_ALLOW_EXTERNAL=*
  • NODE_FUNCTION_ALLOW_BUILTIN=*
    volumes:
  • n8n_data:/home/node/.n8n
volumes:
n8n_data:
Where the important config is - NODE_FUNCTION_ALLOW_EXTERNAL=* Maybe that env var is missing for you?
For the rest I use a traefik reverse proxy but that shouldn’t matter to you.
