UweG
1
Now, I get following from a HTTP-Request:
How can I use a function node to put this in a json like:
create a json with: {"Key": 'Value of the HTTP-Request'};
Hey @UweG!
You can use the Set node to create the JSON.
Do you want to output to be { "key": true } ?
Hey @UweG,
Did you find a solution? Let us know if you’re still stuck with this issue
