This about a existing node: Thehive node
My use case:
The node is missing an operation for appending observables on an exsting alert, currently it only supports the opeation to append a observable on a case.
It would be benificial to support an alert one too, as far as i can see it’s almost identical to the one for case mentioned above…
There is a operation in Alert->Update alert , where you can add an artifact but this is AFAIK only for existing artifacts, and not for appending a new one.
See api documentation page below
http://docs.thehive-project.org/thehive/api/alert/add-observable/
Im not a whiz at js or typescript, so im afraid not
