Throwing an error with Stop & Error using an error workflow
I have an Error Workflow defined in my workflow’s settings, but there are some run conditions where I want to manually trigger an error. How can I use the “Stop and Error” node to generate the error message and then pass that to my Error Workflow?
Maybe this should be turned into a feature request. I had the same expectation that if you intentionally hit a Stop and Error node, and you have an Error Workflow set for the workflow, the specified error workflow should be executed when/if you reach a Stop and Error node. Currently, it appears that is not what happens.
Until the behavior is changed (if it ever is), you probably have to sorta “repeat yourself” and put an Execute Workflow node to explicitly call the error workflow, right ahead of your Stop and Error node.
