Timeout Issue with Workflows Longer Than 60 Seconds
Hello,
I’m running into a timeout problem with my self-hosted n8n installation on Elestio.
The Issue
When I run workflows that take longer than 60 seconds to complete, I don’t get a response:
  • With workflows under 60 seconds: Everything works fine, I get a proper response
  • With workflows over 60 seconds: Initially got 504 Gateway errors
  • After modifying Nginx timeouts to 5 minutes: The request just hangs with no response
My Test Setup
I created a simple test workflow with just:
  1. Webhook node
  2. Wait node (to simulate processing time)
  3. Respond to Webhook node
What I’ve Tried
  • Modified Nginx configuration to increase timeouts to 5 minutes
  • Tested with different wait durations to confirm the 60-second threshold
Has anyone encountered this issue before? Is there a setting in n8n itself that I need to modify for longer-running workflows?
Any help would be greatly appreciated!
Hey @hussein_Abusetta,
Thanks for reporting this.
We have a similar issue here which we’re looking at:
I think it could be the similar. We’re investigating this at the moment and we’ll update on the GitHub issue once we know more.
