Title: N8N103 Section 1 — n8n103/feedback endpoint returns HTTP 200 with an empty body, blocking the Feedback Pipeline exercise
Hi team,
I’m blocked on the N8N103 Section 1 – Feedback Pipeline exercise by what looks like a server-side issue on the Academy training endpoint, not my workflow. Posting full evidence so it’s reproducible.
The problem
GET https://learn.app.n8n.cloud/webhook/course/n8n103/feedback returns HTTP 200 OK with a zero-byte body — so no feedback data comes back and the pipeline can’t complete.
What I’ve ruled out (so this isn’t on my end):
  • Auth is working: with a wrong/missing key the endpoint returns 403 "Authorization data is wrong!". With my valid X-Assessment-ID it returns 200 — but with Content-Length: 0.
  • Reproduces outside n8n: plain curl gives the same result, so it isn’t node configuration.
  • Correct verb: GET is what the endpoint expects.
curl reproduction:
curl -s -D - -H "X-Assessment-ID: <my-assessment-id>" \
→ HTTP/2 200
→ content-type: application/json; charset=utf-8
→ content-length: 0
   (empty body)
Last node output: one item, empty object — [ {} ]
Downstream effect: because feedback_id, customer_name, and message all resolve to nothing from the empty response, the generated reply POST to .../n8n103/reply correctly fails with 422 [Validation Failed].
Details:
  • Course/section: N8N103 – Section 1 (Feedback Pipeline)
  • Endpoint: https://learn.app.n8n.cloud/webhook/course/n8n103/feedback
  • Assessment ID:
  • Tested: 2026-08-15, ~22:08 SGT (UTC+8)
Request: Could someone from the Academy team check whether the mock data source behind n8n103/feedback is down and restore it? This looks like the same class of issue reported here:
Happy to provide execution timestamps or run any diagnostics. Thanks!
Hello,
Our backend instance decided to take a day off. Resulting in a bunch of our workflows breaking. We’re back up now, please try again.
cheers
Hello, same error today.
No fields - item(s) exist, but they’re empty
in all N8N103 hands on exercices
Hello,
We had some backend issues again. I will be working on figuring out why this is recurring and hopefully resolve it today.
cheers,
I’m experiencing a similar issue today (September 18), but with the /reply endpoint.
/feedback works correctly and returns all 10 feedback items, but /reply returns HTTP 200 OK with an empty body (content-length: 0).
I’m using the OpenAI API (gpt-5.4-mini) instead of Groq, as the course allows using another AI provider. I’ve checked the headers, Assessment ID, request body, and executed the entire workflow — same result.
Looks like the N8N103 backend issue may still be occurring.
Hello,
The LLM you use shouldn’t matter. If yo’ure getting an empty return, that usually means one of your parameters is misconfigured and may contain a space.
I’ve checked and our backends are all functioning.
