Hey everyone, n8n function is not working
n8n version: 1.33.1
Database (default: SQLite): Postgres
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
**Operating system:**Ubuntu
Jon
April 18, 2024, 11:14am
2
Hey @NarHakobyan ,
Welcome to the community
I have just taken a quick look and the toJsonString() function appears to be working, Can you run the workflow below and let me know if that has the same issue?
Can you also share the json data you are using so we can test it?
Hi, thanks for reploy, here is the result of the final node
Jon
June 3, 2024, 8:45am
4
Hey @NarHakobyan ,
That is very odd, Can you try upgrading if you have not already to see if you have the same issue?
system
Closed
September 1, 2024, 8:45am
5
