Trouble running external modules in code node
I am trying to run the module ‘google-news-scraper’ in a code node but only managing to get network time-outs (after 3 mins) and struggling to find the source of the problem. I would appreciate anyones help in fault finding. Setup as follows:
const googleNewsScraper = require('google-news-scraper');
async function scrapePage() {
    try {
        // Await the results from the scraper function
        const articles = await googleNewsScraper({ searchTerm: "gardening", prettyURLs: false, logLevel: "info" });
        $input.item[0].json = { articles }; // Directly set articles as the json value
        console.log("All OK");
        return $input.item[0];
    } catch (error) {
        console.error("An error occurred:", error);
        throw error;
return scrapePage();
error received:
Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed. null
I have created a Docker based on @marcus 's github page. I only made a few changes like increasing the Alpine Node version to 18 and using n8n:1.61.0 (latest).
Dockerfile as follows:
FROM node:18-alpine
ARG N8N_VERSION
RUN if [ -z "$N8N_VERSION" ] ; then echo "The N8N_VERSION argument is missing!" ; exit 1; fi
# Update everything and install needed dependencies
RUN apk add --update graphicsmagick tzdata git tini su-exec
# # Set a custom user to not have n8n run as root
USER root
# Install n8n and the also temporary all the packages
# it needs to build it correctly.
RUN apk --update add --virtual build-dependencies python3 build-base ca-certificates && \
        npm_config_user=root npm install -g full-icu n8n@${N8N_VERSION} && \
        apk del build-dependencies \
        && rm -rf /root /tmp/* /var/cache/apk/* && mkdir /root;
# Installs latest Chromium (100) package.
RUN apk add --no-cache \
      chromium \
      nss \
      freetype \
      harfbuzz \
      ttf-freefont \
      yarn
# Tell Puppeteer to skip installing Chrome. We'll be using the installed package.
ENV PUPPETEER_SKIP_CHROMIUM_DOWNLOAD=true \
    PUPPETEER_EXECUTABLE_PATH=/usr/bin/chromium-browser
# Install n8n-nodes-puppeteer
RUN cd /usr/local/lib/node_modules/n8n && npm install n8n-nodes-puppeteer google-news-scraper
# Install fonts
RUN apk --no-cache add --virtual fonts msttcorefonts-installer fontconfig && \
        update-ms-fonts && \
        fc-cache -f && \
        apk del fonts && \
        find  /usr/share/fonts/truetype/msttcorefonts/ -type l -exec unlink {} \; \
ENV NODE_ICU_DATA=/usr/local/lib/node_modules/full-icu
WORKDIR /data
COPY docker-entrypoint.sh /docker-entrypoint.sh
ENTRYPOINT ["tini", "--", "/docker-entrypoint.sh"]
EXPOSE 5678/tcp
The container build and startup looks fine.
I can see that puppeteer and google-news-scraper have been installed locally.
My docker-compose file is as follows:
services:
  n8n:
    build: .
    #image: n8nio/n8n
    container_name: n8n
    ports:
      - "5678:5678"
    volumes:
      - /docker/n8n/data:/data
        #  - /docker/n8n/.n8n:/home/node/.n8n
    #next four lines for the puppeteer build
    privileged: true
    shm_size: "1gb"
    environment:
      - N8N_BASIC_AUTH_ACTIVE=true
      - N8N_BASIC_AUTH_USER=user
      - N8N_BASIC_AUTH_PASSWORD=password
      - N8N_SECURE_COOKIE=false
      - N8N_DIAGNOSTICS_ENABLED=false
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_HOST=db
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_DATABASE=n8n
      - DB_POSTGRESDB_USER=n8n
      - DB_POSTGRESDB_PASSWORD=n8n
      - NODE_FUNCTION_ALLOW_EXTERNAL=axios,qs,google-news-scraper
      - NODE_FUNCTION_ALLOW_BUILTIN=*
      - EXECUTIONS_DATA_SAVE_ON_ERROR=all
      - EXECUTIONS_DATA_SAVE_ON_SUCCESS=all
      - EXECUTIONS_DATA_SAVE_ON_PROGRESS=false
    depends_on:
      - db
    restart: unless-stopped
  db:
    image: postgres:12
    container_name: n8n_db
    volumes:
      - db-data:/var/lib/postgresql/data
    environment:
      - POSTGRES_USER=n8n
      - POSTGRES_PASSWORD=n8n
      - POSTGRES_DB=n8n
volumes:
  db-data:
Finally, after the node times out, I can see that my docker host is maxed out on cpu and multiple (10-15) chromium processes are still running.
  • n8n version: 1.61.0
  • Operating system: Ubuntu Host / Alpine Docker
Thanks for any help in advance.
I appear to have eventually solved my own problem. The main issue was that I hadn’t installed dependencies after the npm install of modules.
I made the following mod to the Dockerfile:
WORKDIR /usr/local/lib/node_modules/n8n
RUN cd /usr/local/lib/node_modules/n8n && npm install n8n-nodes-puppeteer google-news-scraper && npm install
I also had some less significant issues with my js code regarding using the $input object inside a function which became obvious once I had a working docker container.
I might make some adjustments to the docker container now but at least I have a current working n8n container with chromium and puppeteer. Result!!
