My difficulty is very similar to this post, however I need to turn the query into a single object with fields for each parameter so I can evaluate it properly in a filter down the workflow. I can get it to return just the query data but it still places the parameters in a single field. I’m guessing because it does not have a json: property. I’m sending the webhook via GET but I thought there might be a way to transform it. I’ve tried the approach mentioned in the post above, but just can’t get it to transform correctly. Webhook data is below:
"body": {},
"headers": {
"host": "adastacks.app.n8n.cloud",
"x-request-id": "cb4aa892a31ff75b9ef35557bda8d68a",
"x-real-ip": "10.30.0.4",
"x-forwarded-for": "10.30.0.4",
"x-forwarded-proto": "https",
"x-forwarded-host": "adastacks.app.n8n.cloud",
"x-forwarded-port": "443",
"x-scheme": "https",
"accept": "application/json, text/plain, */*",
"user-agent": "axios/0.18.1",
"traceparent": "00-5eec62334025fcb0af6b485451a243cc-e69fa864daf3b49b-00",
"tracestate": "2959370@nr=0-0-2959370-725367163--56a3843f899a8a2a-0-0.249286-1611755280271",
"newrelic": "eyJ2IjpbMCwxXSwiZCI6eyJ0eSI6IkFwcCIsImFjIjoiMjk1OTM3MCIsImFwIjoiNzI1MzY3MTYzIiwidHgiOiI1NmEzODQzZjg5OWE4YTJhIiwidHIiOiI1ZWVjNjIzMzQwMjVmY2IwYWY2YjQ4NTQ1MWEyNDNjYyIsInByIjowLjI0OTI4Niwic2EiOmZhbHNlLCJ0aSI6MTYxMTc1NTI4MDI3MX19"
"query": {
"api_key": "7zPn4ve4J7snNVBnyLUOiDKJ",
"to_phone": "18643287989",
"body": "Click here: https://google.com"
