Trouble with converting to PDF
So, I set up a workflow so that when someone uploads a website, it automatically converts to a PDF; however, when I execute the workflow, the PDF comes out as corrupt. I tried changing the format and request, but it’s still coming over as corrupt.
File coming over as corrupt
“nodes”: [
“parameters”: {
“pollTimes”: {
“item”: [
“mode”: “everyMinute”
“documentId”: {
“__rl”: true,
“value”: “1eyX4SrEmlGe-wANg5-Bbq6tqC2_Dzt28hE2OybLn6LU”,
“mode”: “id”
“sheetName”: {
“__rl”: true,
“value”: “gid=0”,
“mode”: “list”,
“cachedResultName”: “Sheet1”,
“cachedResultUrl”: “https://docs.google.com/spreadsheets/d/1eyX4SrEmlGe-wANg5-Bbq6tqC2_Dzt28hE2OybLn6LU/edit#gid=0
“event”: “rowUpdate”,
“options”: {}
“type”: “n8n-nodes-base.googleSheetsTrigger”,
“typeVersion”: 1,
“position”: [
16,
-112
“id”: “6077d4fd-3d01-4cc7-b51b-0939c6a7764f”,
“name”: “Google Sheets Trigger”,
“credentials”: {
“googleSheetsTriggerOAuth2Api”: {
“id”: “iUeU75mHXW1tR9FE”,
“name”: “Google Sheets Trigger account 2”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “59493c86-dcfa-4e05-b980-18a91ac6a264”,
“name”: “Full Name”,
“value”: “={{ $json[‘First Name|name-1’] }} {{ $json[‘Last Name|name-2’] }}”,
“type”: “string”
“id”: “ddd3afef-737b-48ed-b103-ce5ea775b386”,
“name”: "Email ",
“value”: “={{ $json[‘Email Address|email-1’] }}”,
“type”: “string”
“id”: “0f019a63-b588-4793-9250-6326bf1cf471”,
“name”: “URL”,
“value”: “={{ $json[‘URL|url-1’] }}”,
“type”: “string”
“options”: {}
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
192,
-240
“id”: “807a09e4-54a2-43ff-9a6b-6df567fbffd9”,
“name”: “Clean Up”
“parameters”: {
“method”: “POST”,
“url”: “https://api.firecrawl.dev/v1/scrape”,
“genericAuthType”: “httpHeaderAuth”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “Authorization”,
“value”: “Bearer fc-b767ef3e16a04f6e807ace871a9e63db”
“sendBody”: true,
“specifyBody”: “json”,
“jsonBody”: “={\n "url": "{{ $json.URL }}",\n "formats": ["json"],\n "jsonOptions": {\n "schema": {\n "type": "object",\n "properties": {\n "url": { "type": "string" },\n "title": { "type": "string" },\n "body": { "type": "string" }\n },\n "required": ["url", "title", "body"]\n }\n }\n}”,
“options”: {
“response”: {
“response”: {
“fullResponse”: true,
“responseFormat”: “json”
“typeVersion”: 4.2,
“position”: [
400,
-368
“id”: “426632f0-7ec2-4495-a96d-5686a26c7e0e”,
“name”: “Extract n Convert”,
“credentials”: {
“httpHeaderAuth”: {
“id”: “zE8sKGFBwx2cDeq5”,
“name”: “Header Auth account”
“parameters”: {
“operation”: “xlsx”,
“options”: {}
“type”: “n8n-nodes-base.convertToFile”,
“typeVersion”: 1.1,
“position”: [
608,
-368
“id”: “0184ab87-6a3f-40c5-bbc5-2c4941b4831c”,
“name”: “Convert to File”
“parameters”: {
“operation”: “Convert To PDF”,
“advancedOptions”: {}
“type”: “n8n-nodes-pdf4me.pdf4me”,
“typeVersion”: 1,
“position”: [
816,
-368
“id”: “f5fb744b-b678-4a94-87c1-05e5816297ac”,
“name”: “PDF4ME”,
“credentials”: {
“pdf4meApi”: {
“id”: “Q4OckR7sGwGSA4k5”,
“name”: “PDF4ME account”
“connections”: {
“Google Sheets Trigger”: {
“main”: [
“node”: “Clean Up”,
“type”: “main”,
“index”: 0
“Clean Up”: {
“main”: [
“node”: “Extract n Convert”,
“type”: “main”,
“index”: 0
“Extract n Convert”: {
“main”: [
“node”: “Convert to File”,
“type”: “main”,
“index”: 0
“Convert to File”: {
“main”: [
“node”: “PDF4ME”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “82b31d42a861c823d633d8f4a1e67953b415488fa4df57b9aac7496163ec196b”
  • n8n version: latest
  • Operating system: 11
Hi @Flowzy , i tried this, i dunno if it’s similar with what you’re doing but i dont receive the error, but i hope it can help, maybe because the size of the file is too big or the converting from firecrawl have some problem
The thing is I got to output it in pdf but that was the website but some header on the http node I converted this to binary and convert it again to binary and sent to pdf4me but it not showing anything for the website that it was originally meant for
Hello From the “PDF4me Support Team” - Support. We would like to help you out. Please Contact us at [email protected]
I ran into the exact same issue when I tried something similar — the PDF would always come out corrupted. After some trial and error, I realized the problem wasn’t the node generating the PDF itself, but the way the data format was being handled. If you leave it as JSON or text, the file gets corrupted when saved.
The key was to switch the output to binary before saving or sending it. In my case, in n8n I had to make sure the response was handled as binary and then use the correct data field so the PDF wouldn’t break.
So in short: the PDF isn’t really broken, it’s just being interpreted in the wrong format. Change the output to binary and it should open fine.
These are the values that were output once it was sent to PDF4Me, which is corrupt, as you can see the data size changes from KB to B which means that the HTTP request either didnt convert properly or the convert to node doet read the inital binary that was sent.
I dont think the issue is in you but I will contact you if it is
