Trouble with Node Execution Visibility in n8n After Moving to External Network
I’m using n8n on my personal computer and have set it up to be accessible from an external network. Previously, when I was running n8n locally, the execution status of the nodes in my workflows was visible and functioning normally. However, I’m now experiencing an issue where I cannot see which nodes are currently executing or their statuses. The workflow does not complete until I click the “Stop current execution” button, and when I do, it skips the intermediate nodes and directly shows the results. I’ve checked the connection settings and ensured that the environment is configured correctly, but the problem persists. I’m looking for solutions or troubleshooting steps to resolve this issue.
There are no error messages displayed.
  • n8n version: 1.59.3
  • Database (default: SQLite): SQLite (default)
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own (default)
  • Running n8n via (Docker, npm, n8n cloud, desktop app): npm (or whichever method you used to run n8n)
  • Operating system: Windows10
Hi @crew2030
Thanks for posting here and welcome to the community! :cake:
How did you set up your external network? Can you share your reverse proxy settings? Are you using nginx?
