Hi HemaraldHerald,
at least I am not alone being confused
The webhook receives Blog Posts. If they are in the database the Merge
receives the previously stored dataset on Input 1 (I need the id
from the Database to update the record and finally want to do some magic if an update happens after more than two days after firstseen
Here is a live sample from a testpost being redacted.
"id":511,
"postid":82,
"blogid":30,
"authorid":1,
"firstseen":"2023-07-10T10:39:14.000Z",
"feature":null,
"imgurl":" https://somesiteurl.com/image.png",
"title":" Another Test Post6",
"abstract":" Now we are a bit upset if this won’t work either… ",
"permalink":" https://somesiteurl.com/another-test-post/"
Input 2 is directly wired to the incomming Data from the webhook (containing the update information)
"PostId":"82",
"BlogId":"30",
"UserId":"1",
"Title":"Another Test Post7",
"Authorname":"Redacted",
"Blogname":"Redacted",
"Link":"https://somesiteurl.com/another-test-post/",
"Thumbnail":"https://somesiteurl.com/image.png",
"Abstract":"Now we are a bit upset if this won’t work either… äøåÖ… ",
"Channel":"",
"FeaturedImage":"https://somesiteurl.com/image.png"
The Merge Result is:
"id":511,
"postid":82,
"blogid":30,
"authorid":1,
"feature":null,
"permalink":" https://somesiteurl.com/another-test-post/",
"PostId":"82",
"BlogId":"30",
"UserId":"1",
"Channel":"",
