Trying to create simple connection to Notion
Hey guys,
Losing my mind trying to set this up as I imagine this is supposed to be a simple kind of connection and I have tried so many combinations now that I am about to give up and move to MAKE.
I was hoping to making a project management tool for myself that can connect to a private database for client access within Notion.
I cant seem to figure out how to stop duplicates from happening when cross referencing existing entries. Is there a simpler way to do this?
Hey @Eden_Stone , could you clarify where duplication takes place, please? How do you cross-reference the entries?
Not having a clear understanding of your problem, I would say you are missing Merge node which is typically suitable for the cross-referencing task. It might also be possible to utilize Compare Datasets node for that purpose.
