Trying to use Slack as a tool for the AI engine, party works
Hi i’m trying to use a tool in the AI Agent. I connected another flow that has 1 purpose, to check online presence of a user. I have 7 developers and it correctly fired 7 times the sub workflow. But instead of feeding it everytime with the next user Id its sending everytime the same user. I had to use the $fromAI since I didn’t found a way to drag the query into the target field. See picture for more details
  • n8n version: 1.74.1 (online)
I still have the same issue, and really need some help.
Tried a lot of things and thought it would be easy to iterate through the list.
But am really stuck at the correct syntax
instance information
Debug info
core
  • n8nVersion: 1.76.1
  • platform: docker (cloud)
  • nodeJsVersion: 20.18.1
  • database: sqlite
  • executionMode: regular
  • concurrency: 5
  • license: community
  • consumerId: 00000000-0000-0000-0000-000000000000
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: filesystem
pruning
  • enabled: true
  • maxAge: 168 hours
  • maxCount: 2500 executions
client
  • userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/132.0.0.0 safari/537.36
  • isTouchDevice: false
Generated at: 2025-02-08T11:54:35.910Z
No one that can help me with this?
Hi @Rick_Hoebee,
Thanks for posting! It would be great if you can share the actual workflow JSON instead of screenshots!
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
But from a quick look, I don’t think you can use the $fromAI tool in the workflow subnode.
The $fromAI() function is only available for app node tools connected to the Tools Agent. It isn’t possible to use the $fromAI() function with the Call n8n Workflow, Code, HTTP Request, or other cluster sub-nodes.
Could you try referencing it as siimply {{ $json.query.username }}?
