Hi - n8n noob (but make.com semi-pro) here, trying to figure out the best way to run a workflow:
- I’d like to run the top branch “n” times - then wait for 5 seconds, and then run a second branch that is able to retrieve results from the top branch.
- The top aggregate isn’t working the way I expected, but that’s a different problem I guess…
3.Any way to get the second branch to see the results from the top one?
Many Thanks!!
Here’s a workflow that represents the issue…
- n8n version: 1.74.1
- Database (default: SQLite):?
- n8n EXECUTIONS_PROCESS setting (default: own, main):?
- Running n8n: via n8n cloud
