Tutorial to navigating SQL and XML in n8n
We’re back with another insightful guide! This time, we’re delving deep into the world of SQL and XML within the versatile n8n workflow automation tool.
Eduard and Yulia will walk you through the process of exporting SQL data to XML format and importing XML back to SQL. But we don’t stop there! We’ll also show you how to style your XML files with the powerful XSLT and guide you on what to do next with your sleek XML output.
Plus, we’re sharing three workflows to help you apply what you’ve learned immediately.
So, are you ready to discover the magic of SQL/XML integration in n8n?
We are looking forward to hearing your thoughts and experiences. Let’s master this SQL and XML tango together!
