Hello good folks of n8n, I have an issue that you might be able to help me with
I am following the instructions to create a custom node so I could use the ‘http’ module in my functions. I keep on getting the error error TS1003: Identifier expected. when i try to build it.
My custom node code is the default code plus this line after the import statements import * as http from 'http' . Here’s the complete code for your reference custom n8n node · GitHub
It seems to be a typescript specific error but despite searching online i am unable to fix this, any help regarding this would be greatly appreciated.
Lol my sleep deprived brain missed that last night.
Thanks for the pointer, I am able to successfully build the project but I have another question.
After building the node i restarted n8n by sudo docker-compose stop and then sudo docker-compose up -d
on the website when I try to access my custom node I am unable to find it.
According to my docker-compose.yml file the n8n volumes folder is /root/.n8n and my custom node files are already present in the folder, but still the custom node doesn’t show up on the vue app UI.
/root/.n8n is where it does get mounted into the docker-container. So if you want that your local /root/.n8n is the same as the /root/.n8n in your docker container you would have to change that line to:
- /root/.n8n:/root/.n8n
But be aware that if you do that, you should first copy the .n8n folder from wherever ${DATA_FOLDER} points to and copy it to /root/.n8n because else it will not display you the existing workflows anymore (as in this folder is also the SQLite database).
