UI Input/Output confused with two code nodes
I have two code nodes, each set to “Run once for each item”. In my case, there is only one row, consisting of an array of records.
After running the workflow:
  • When I double click on Step 1, the input shown is the input for step 1 but the output shown is the output for step 2.
  • When I double click on Step 2, both the input and the output displayed are the output for step 2.
  • n8n version: 1.64.3
  • Operating system: Amazon Linux 2023
Hey @Lee_S , your example indeed produces unexpected results. We will look further into why it is happening. I can only assume right now that it has something to do with consecutive use of Code nodes.
Thanks for bringing it to our attention.
