- n8n version: 1.53.2
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker, localhost
- Operating system: Win 11 pro
I could easily attach binary in JSON body but how to make it work for n8n?
Thanks
BramKn
2
Hi @weilies_chok
You need to make sure to select the right content type.
i tried any combination i could think off… still failed lol
BramKn
4
Hi @weilies_chok
You need to put in the name of the binary not an expression.
so in this case just: “data”
thanks! working!
but what if in future i wanted to use the “data” not in the node right after it output the binary? if i want to use the exported binary 3 nodes later?
BramKn
6
You will need to join it back in with a merge node.
system
Closed
7
