Issue: Unexpected Behavior When Using merge Node
Description
I’m experiencing unexpected behavior when using the merge node in my workflow. Here’s what’s happening:
- When I add the
mergenode, the workflow breaks.
When I remove the
mergenode, everything runs perfectly.
I use the
mergenode in other workflows without any issues, so this seems to be a specific case.
Context
To avoid generating a response for every message sent, I integrated Redis as a way to control flow or rate limit responses.
In this setup, I need to merge inputs before proceeding, which is why including the merge node is essential.
What I Need
Any suggestions or guidance on how to:
- Use the
mergenode properly in this scenario. - Diagnose why it’s breaking the workflow in this specific case.
Workflow execution had an error
Cannot read properties of undefined (reading ‘execute’)
- n8n version: Version 1.90.2
- Database (default: SQLite):
- Running n8n via (Docker, npm, n8n cloud, desktop app): Railway template
- Operating system:
