There is a process that has 2 format outputs.
Goal: to make it so that there is one format output that would output a value in the client_data field regardless of how we got it, by ID or by Username.
Is this possible?
Let me know if this works:
Hmm… in that case, try replacing for one of these expressions:
{{ $node["Get by Username"].json || $node["Get by TG ID"].json }}
{{ $node["Get by Username"].json ?? $node["Get by TG ID"].json }}
{{ $if(typeof $node["Get by Username"].json == "undefined", $node["Get by TG ID"].json) }}
EDIT
Sorry, that wouldn’t work either.
Here’s an example using the Merge node that works:
yes, everything works!
thank you very much!
