Unknown encoding: iso-8859-1
I was using this workflow normally, and for the past few days, I’ve been getting this error.
  • n8n version: 1.56.2
  • Operating system: Win 10
Hi @miguelraatz,
Thanks for sharing the workflow, could you explain a bit more about what your workflow does and where in the workflow you get the error, what the error says, etc? The more descriptive you are, the easier it is for the community to help :slight_smile:
Hi.
Of course, the error occurs in the HTTP node when trying to download a .csv file.
Hi @miguelraatz,
the error suggests that there’s an encoding mismatch between the HTTP request and the requested zip file. the n8n HTTP request node uses UTF-8 encoding by default and it looks like you’re trying to access a zip file that’s encoded in iso-8859-1.
I’m not sure why this is happening suddenly when it was working normally before though. Has something changed in the request or the ZIP file you’re requesting? Could it have been saved in a different encoding?
You can try converting the content type with a library like iconv-lite suggested in a similar issue here or try to specify the request headers suggested in this post. Could you try these out to see if that does the trick?
I tried using this approach, and it still didn’t work.
Still a problem here folks with API requests too. Still not dealt with?
