I’ve n8n on my server via docker.
I run command docker pull n8nio/n8n and it downloads and extract files, but changes did not affect. I tried restart container by docker restart n8n but no changes.
How can I put a new image into an old container? Do I need to remove the container and make a new one?
I know that data like workflows are stored somewhere else, but I had some env variables for simply auth and webhook tunnel, so every time i am wondering if I need to write those variables always during update?
I am new with docker, so sorry if it’s stupid question, but what should I do after
So as I remember I installed n8n via docker, no docker-compose. I installed it now, but server sais:
Can't find a suitable configuration file in this directory or any parent. Are you in the right directory?
What makes sense bc I am in my home directory, how can I get to know where is my n8n dir? If, I can update n8n via docker-compose despite that installed via docker.
I am not sure you can update n8n that was installed via docker, using docker-compose.
I would suggest you run the docker ps command to get the running containers. You can also run docker image ls to get a list of all the images. It should also show you the version you’re using.
You can run the ls -a command to list the directories that are present in the root directory of your server.
