[URGENT] Failure to recover data after VPS crash (SQLite) – Issue loading administrator data
Hello n8n Team/Community,
I need help analyzing and recovering data after a serious server failure (VPS Mikrus) and the loss of current data. I’ve reached a stage where the n8n container is running, but it’s not loading the saved workflows.
:gear: Configuration Details
  • n8n Version: 1.113.3 (latest available at the time of the last run)
  • Hosting Method: Docker Compose
  • Database: SQLite (database.sqlite)
  • Server: Linux VPS (Mikrus)
:police_car_light: Situation Description and Steps Taken
  1. Failure: My VPS crashed. I lost the current data (from the last week), but I had two older backups.
  2. Restoration: I attempted to restore data from the oldest but only available file: n8n_backup_2025-10-05.tar.gz.
  3. File Verification: After unzipping, the database.sqlite file is present in the /root/n8n/data/ directory and has a size of ~536 KB. Permissions were fixed (chown 1000:1000).
:cross_mark: The Problem (Diagnosis)
Despite the correct upload of the database.sqlite file and the container starting successfully, n8n:
  1. Does not load administrator data: When I visit the URL, instead of the login screen, I see “Set up owner account”.
  2. No Workflows: After creating a new administrator account, the dashboard is completely empty (I see “everything new”). It appears n8n considers the database empty or incompatible.
:red_question_mark: Questions for the Community/Support
  1. Could the issue be due to corruption in the user/authentication tables within the database.sqlite file?
  2. Is there a tool to check the integrity of my database.sqlite file or to extract only the workflow data from it (without credentials) for manual import?
  3. Could the lack of a manually set N8N_ENCRYPTION_KEY variable in the .env file be causing this issue (the database used a default/old key and is unreadable by the new installation)?
If possible, I would be willing to provide the database.sqlite file for analysis to verify its content.
Thank you for any help and guidance!
Here’s how to recover your SQLite database:
- First try the SQLite recovery command from [elest.io]( Repair N8N SQLite database ):
sqlite3 database.sqlite .recover > recover.sqlite
mv database.sqlite database-old.sqlite
mv recover.sqlite database.sqlite
- If that fails, consider:
