šŸ†˜ URGENT: WhatsApp Flow Endpoint - "Response body is not Base64 encoded" Error
Platform: Self-hosted n8n 1.108.1
Issue: WhatsApp Flow endpoint validation failing
Error: ā€œResponse body is not Base64 encodedā€ + ā€œFailed to decrypt responseā€
:bullseye: What I’m Trying to Achieve
Building a WhatsApp Flow endpoint for Meta’s WhatsApp Business Manager that:
  • Handles ping/health check requests
  • Processes encrypted Flow submissions (INIT, data_exchange)
  • Returns properly encrypted Base64 responses per Meta’s specification
:wrench: Current Setup
  • Self-hosted n8n with Docker Compose + Traefik
  • SSL enabled at https://n8n.srv977544.hstgr.cloud
  • Environment variables set:
    text
    N8N_ENABLE_RAW_EXECUTION=true NODE_FUNCTION_ALLOW_BUILTIN=fs,crypto,path,os
  • Private key mounted correctly (PKCS#8 encrypted format)
  • Workflow structure: Webhook → Code Node → Respond to Webhook
:collision: The Problem
WhatsApp Flow validation keeps failing with:
  1. ā€œResponse body is not Base64 encodedā€ - Even when returning Base64 strings
  2. ā€œFailed to decrypt responseā€ - WhatsApp can’t decrypt my encrypted responses
:test_tube: What I’ve Tried
Attempt 1: Raw Base64 Response
javascript
returnencryptedData.toString('base64');// n8n error: not array format
Attempt 2: JSON Wrapped Response
javascript
return[{ json: { base64Response: encrypted.toString('base64') } }];// Respond to Webhook: {{$json.base64Response}}
Attempt 3: Different Encryption Approaches
  • Random AES keys for ping → WhatsApp can’t decrypt
  • Simple Base64 JSON for ping → ā€œnot Base64 encodedā€ error
  • Using WhatsApp’s provided AES keys → still fails
:clipboard: Current Code Structure
javascript
constitems = $input.all();constbody = items[0].json; // For ping requests if(body.action === 'ping' || !body.encrypted_flow_data) { constresponseData = { version: "3.0", data: { status: "active" } }; // What format should this return???} // For encrypted requests // RSA decrypt AES key → AES-GCM decrypt → process → encrypt response
:thinking: Key Questions
  1. Response format: Should ping responses be simple Base64-encoded JSON or encrypted data?
  2. n8n compatibility: How to return raw Base64 strings that WhatsApp expects?
  3. Encryption keys: For ping responses, what keys should I use if none provided?
  4. Meta specification: Anyone successfully implemented WhatsApp Flow endpoints in n8n?
:link: Meta Documentation Reference
Following: https://developers.facebook.com/docs/whatsapp/flows/guides/implementingyourflowendpoint
:folded_hands: Looking For
  • Working n8n WhatsApp Flow implementation examples
  • Encryption strategy for ping vs encrypted requests
  • Response format that passes Meta validation
  • Environment variable configurations that work
Has anyone successfully implemented WhatsApp Flow endpoints (not regular WhatsApp messaging) with n8n? Any insights on the proper encryption/response format would be hugely appreciated!
Tags: #whatsapp-flow #encryption #base64 #meta-api #webhook-response
I faced a similar headache when working with file/image uploads in n8n — the platform often wraps or misformats binary/Base64 data, which leads to errors like the one you’re seeing (not Base64 encoded).
I wrote a blog explaining how to correctly handle binary ↔ Base64 data in n8n, and return it in the raw format that external APIs (like Meta’s WhatsApp Flow) expect. While it doesn’t cover the RSA/AES-GCM crypto part, the Base64 response formatting piece should help you clear that specific error.
https://medium.com/@rupaliofficialmail/how-to-handle-image-uploads-in-n8n-forms-binary-file-fix-d4cd2cab469d
