Using Antidetect Profiles + n8n + AI to Manage Multi-Account Workflows at Scale
Hi everyone,
I wanted to share a setup I’ve been testing that combines n8n, antidetect browser profiles, and prompt-based automation agents to orchestrate multi-account tasks. This is especially helpful if you manage workflows involving different user identities across platforms (think: account creation, login flows, form submissions, etc).
The Problem
Handling workflows for 10+ user accounts manually is tedious, error-prone, and often flagged due to fingerprint duplication. Using the same IP, browser, or cookie context leads to bans or shadowbans.
The Stack
Here’s the system I’m currently using:
  • n8n: As the central orchestrator for all logic, retries, triggers, data collection, and scheduling.
  • Hidemium (Antidetect Browser): Each account is isolated in its own browser profile, complete with separate fingerprint, IP, and device emulation.
  • Prompt-Based Scripting: I use AI agents that respond to prompts like “Log in to Gmail and check unread messages,” and the agent handles UI navigation inside the Hidemium browser context.
  • API/Webhook Layer: Hidemium exposes local APIs for interacting with browser tabs, which I call from n8n nodes or via a custom webhook setup.
Sample Workflow
  1. Trigger: n8n is triggered by webhook or schedule.
  2. Data Input: Pull list of accounts + tasks from Google Sheets or Airtable.
  3. Open Profile: For each task, n8n sends a command to open the corresponding Hidemium profile.
  4. Run Task: A local AI script executes the web interaction (e.g., login, scrape, post, click).
  5. Close & Log: Task result is logged back into the database; browser is closed.
Challenges
  • Latency: Prompt-based automation is slower than traditional scripting but more resilient to DOM changes.
  • Captcha Handling: Still requires fallback or integration with third-party services.
  • Error Recovery: I’ve added checkpoints in n8n to detect and reassign failed profiles.
Why It Works
Using separate fingerprinted browsers reduces flagging. n8n handles orchestration and logic branching beautifully, and AI prompt scripting lowers the bar for writing brittle scripts manually. Combined, this setup allows me to automate operations over 50+ browser identities reliably.
Anyone else experimenting with multi-identity workflows or combining AI + n8n orchestration?
I’d love to hear how others are integrating with headless or profile-isolated browsers.
Hey, glad to hear my post resonated with what you’re building — your workflow sounds like a really well-structured pipeline.
For your question: yes, my current setup is running locally. I haven’t moved to Hidemium’s cloud infrastructure yet, mainly because local gives me more control over API calls, profile storage, and integration timing with n8n. From what I’ve tested, Hidemium’s automation APIs are designed to be called from a local instance, so most of my orchestration is just n8n sending HTTP requests to that local endpoint.
On the scripting side, my approach is mostly:
  1. Keep actions modular — I split the automation into “atomic” prompt scripts (login, form fill, navigation) rather than one giant flow. This makes retries easier.
  2. Use checkpoints — after each critical step, I let the script return a status to n8n so it can decide whether to retry, skip, or reassign the profile.
  3. Prompt patterns — instead of giving AI the entire task at once, I guide it step-by-step (“Open Gmail login”, wait for DOM check, then “Enter credentials”, etc.). This reduces errors when the DOM changes.
If you’re hitting roadblocks with the API, I’d recommend starting with simple tab-control and element-interaction commands first, and once those are stable, layering in the AI navigation.
Would be curious to see how your TikTok creation flow behaves under multiple profiles — that’s a space I haven’t explored much yet.
Hey Abert, how can I contact you?
