Using binary and JSON data together
I’m trying to transfer an ai-generated video title to the Youtube upload node and upload a video with a dynamic title accordingly. However, the Youtube upload node sees either the binary with the video or the dynamic title, node merge does not help. Is there any way to pass two or more parameters to the Youtube upload node?
This operation expects the node’s input data to contain a binary file ‘data’, but none was found [item 0]
  • **n8n version:**1.112.5
  • Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
  • Operating system: windows 11
The issue is likely in your merge node. Try to change the mode to combine by all possible combinations., so that you have a single item of output from the merge node - containing both the JSON as well as the binary.
