Using Code node to process two JSONs
I have two JSON output from previous node, simple format like this:
        "id": "HDarLEZSZowtXqhblWXxfg",
        "name": "Profile"
        "id": "HK_nEu__ciKtKBo3R4IGTw",
        "name": "Orders"
        "id": "HAlbab7tFBNezyd5nFq3RA",
        "name": "Profile"
        "id": "HFazxo5KT5bAwm7R_jZNxQ",
        "name": "Orders"
I want to output a mapping like this based on the name:
  "HDarLEZSZowtXqhblWXxfg": "HAlbab7tFBNezyd5nFq3RA",  // Profile
  "HK_nEu__ciKtKBo3R4IGTw": "HFazxo5KT5bAwm7R_jZNxQ"   // Orders
I asked ChatGPT and it gives me the code as follow:
// Load both lists
const oldList = $('Old List').items.map(item => item.json); // e.g. Profile, Orders
const newList = $('New List').items.map(item => item.json); // Full CDP schema
// Create a name -> id map from newList
const newMap = {};
for (const entry of newList) {
  newMap[entry.name] = entry.id;
// Build replacement map: old ID -> new ID (when name matches)
const replacements = {};
for (const entry of oldList) {
  const newId = newMap[entry.name];
  if (newId) {
    replacements[entry.id] = newId;
return [
    json: replacements
However, it is not working. Error message “Cannot read properties of undefined (reading ‘map’) [line 2]”. The “.items” is red underlined, seems it is not a correct function.
May I know what is the correct way to do it?
Many Thanks,
Kai
Hey @Kai_C
Try this
const oldList = $('Old List').all().map(item => item.json);
const newList = $('New List').all().map(item => item.json);
// Create mapping
oldList.forEach(oldItem => {
    const newItem = newList.find(newItem => newItem.name === oldItem.name);
    if (newItem) {
        replacements[oldItem.id] = newItem.id;
return [{ json: replacements }];
Thanks it works!
