Using discord and getting error when trying to send messages
Hi. my discord node just will not run anymore. No changes on my part.
Got this error:
From node info: Other info
Item Index
0
Node type
n8n-nodes-base.discord
Node version
2 (Latest)
n8n version
1.90.2 (Self Hosted)
Time
5.5.2025, 12:05:00
Stack trace
NodeOperationError: at ExecuteContext.parseDiscordError (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/helpers/utils.js:97:10) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/actions/webhook/sendLegacy.operation.js:145:50) at processTicksAndRejections (node:internal/process/task_queues:95:5) at ExecuteContext.router (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/actions/router.js:87:20) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/DiscordV2.node.js:42:12) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:681:27) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:915:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1246:20
