Using HTTP Request to connect to Oracle NetSuite Endpoint
As there is no Standard Node to connect with Oracle NetSuite, I used “HTTP Request” to connect the REST SuiteTalk WebService in NetSuite. I can successfully connect to those EndPoint (Get/POST) by using Token-based Authentication.
However, when I try to run the “Second time”, Authorisation failed (i.e. please check your credentials)
However, I can run in the POSTMAN with same login information without any problem.
I am curious if there is any problem with N8N cloud Service.
Glad to hear if anyone has similar experience. Thank you
Hi @Wil
Can you share how you’ve configured the HTTP request node? It sounds like the token expires after a short time. Does the NetSuite API provide a Request Token URL? You could probably use a Generic Credential in the HTTP Request node to get the refresh token.
